Hotkey only active in Window Title [5.10]
Nmk
Post by Nmk » Jan 30th, ’23, 12:36
I recently updated to 5.10 on my Windows 11 machine.
Now, it seems like my Shortcuts which are restricted to specific windows are not working any more. The shortcut work well, when I remove the given title. This reduces my shortcuts a lot because I have a bunch of duplicated keys which differ only in the title.
Is it me, again? Because the colour issue was caused by myself. :roll:
Cheers
nmk
Post by Tom » Jan 31st, ’23, 07:25
Nothing changed in 5.10, please check your settings or contact our support.
Nmk
Post by Nmk » Feb 2nd, ’23, 14:29
I went into the settings right after installing 5.10 just to see what's new. While doing that, I have changed some settings.
My restricted shortcuts are working again, when disabling <Correct sentence capitals>.
Preferences > Functions > Auto-correct > Correct sentence capitals
I cannot see any connection between that. But I can give up on letter case corrections.
Post by Tom » Feb 2nd, ’23, 21:23
Thanks for reporting this. We will resolve it in the next release. ;)
BethanyBurgess
Post by BethanyBurgess » Feb 16th, ’23, 07:57
Thanks for information!
Drakemoor
Post by Drakemoor » Aug 18th, ’23, 23:20
This is still an issue in 5.12
It would be nice if it got fixed.
Thanks.
Post by Marko » Aug 20th, ’23, 20:43
We are working on it, thanks.
Drakemoor
Post by Drakemoor » Aug 21st, ’23, 15:43
Thank you! Good to know. 🙇‍♂️
Drakemoor
Post by Drakemoor » Feb 3rd, ’24, 19:00
This is still an issue in 5.14.
Has someone found a workaround?
