Just installed on new laptop. Ver 5.03 Using old DB file.
Can not make any changes on preference window items as there is no OK button to apply changes.
also, none of the text expanders are working.
I also tried going to the default settings DB, no luck.
Have reinstalled with no luck.
No OK or cancel button on preference window
Try to set the Preferences to defaults (select ALL option).
Use File/Open to open the default Settings.fdb file. If this doesn’t work then contact us on the support mail.
