Error: Out of memory
=Jagz=
Post by =Jagz= » Jan 24th, ’20, 19:24
Not sure if this is related to my laptop memory or a FastKey issue.
Getting this error message:
Error: Out of memory.
Line"
18996: Sleep.50
18997: if OptMem = 1
18998: EmptyMem()
18999: Return
19001: Loop,CLimax+1
19002: {
19003: a:=CLimax-A_lndex"-2, a1:=a-1
—> 19004: clip%a% := clip%a1%
19005: clipname%a% := clipname%a1%
19006: if (clipname%a%<>") && CLComplete
19007: {
19008: cc:= SubStr(clipname%a%,1,lnStr(clipname%a%,"
19009: cc = %cc%
19010: ClipList := ClipList. (cc ? cc : clipname%a%)."
19011:}
The current thread will exit.
Post by Tom » Jan 29th, ’20, 13:28
Can you reproduce it? Exact steps would be great.
=Jagz=
Post by =Jagz= » Jan 29th, ’20, 17:02
No I can't. It is intermittent and hasn't happened again for a while. Perhaps it was related to a resource shortage on my laptop? It was occurring when I had multiple programs open.
If it reoccurs, with any sort of regularity, I'll try to recreate the issue and re-post.
Thanks for taking the time to respond!
f@stkeys
Post by f@stkeys » Apr 1st, ’21, 17:03
Also seeing essentially the same error:
FastKeys.exe
20117: Sleep,50
20118: if OptMem = 1
20119: EmptyMem()
20120: Return
20122: Loop,CLimax+1
20123: {
20124: a:=CLimax-A_Index+2, a1:=a-1
20125: clip%a% := clip%a1%
20126: clipname%a% := clipname%a1%
20127: }
20128: Return
20130: Loop, CLimax-1
20131: {
20132: a:=A_Index+1, a1=a+1
20133: if (clipname%a%=clipname1)
After awhile of copy/pasting content, the error starts to occur on every copy action.
Clipboard history size is 30. System itself has plenty of available memory.
If FastKeys is exited and started again, the error does not resume until after some number of copy/paste actions.
Post by Tom » Apr 4th, ’21, 11:19
Strange. Do you use another similar software or a clipboard manager? Can you try resetting the Clipboard Manager preferences to see if this helps?
Do you copy a very large content?
f@stkeys
Post by f@stkeys » Apr 5th, ’21, 14:40
Thank you for the reply!
No other clipboard manager or similar software is used.
The Clipboard Manager preferences were reset. Will report any additional errors if they arise.
dbrian
Post by dbrian » Apr 25th, ’21, 02:21
Same error here. Just started a couple days ago. No new software. Error pops up any time I copy/cut/paste. Annoying.
