Double click on your Ctrl-Alt-U shortcut and make a change in the command field as explained above.
If not working please send me an mail and we will see what might be an issue with your setup.
Reload
Oh, I understood ! I thought the issue was broader and i didn't think to edit THE command.
So i did, change sound by son.
Commands runned every tim but windows audio dvice shutted down immediately.
I changed the command for "Sound and Audio" command
and it seems to run correctly now
I'll post here if i encounter any problem of this subject
Thank you
Run mmsys.cplI'll post here if i encounter any problem of this subject
Thank you
