Reload
user_7788
Post by user_7788 » Feb 25th, ’14, 03:55
Hello and first, thank you for your incredible app, really.
I have Windows 7 and often,fastkeys seems "unloaded" (autocomplete or shorcuts don't run) and i must right click on the task bar icon then "reload" to make them run again.
Is it a known bug or something i miss ?
Thank you
Post by Marko » Feb 25th, ’14, 08:35
Thanks for reporting this.
I don't experience this issue so it would be great if you could let me know under which specific scenario this happens that we could reproduce and fix it. Thanks for your help!
user_7788
Post by user_7788 » Feb 25th, ’14, 12:58
I did not encounter specific scenarios wich conduced me to this result. It seems to happen randomly. I saw an article few days ago (don't remember the link) which encouters same issues. I'll try to tests some scenarios end reproduce bugs.
NOTE : I have dexpot installed on my computer. I'll try to not open it on windows lauching.
user_7788
Post by user_7788 » Feb 25th, ’14, 16:25
I can exclude Dexpot from beeing responsible. I continue to check ....
Here the list of other app's i'm using :
- MS OneNote
- 7++tweaker
- directory opus
- spotify
- stickies
Post by Marko » Feb 26th, ’14, 00:36
Thanks. You can also send me an email with more details about your setup (modules or specific commands used, etc.) and we will try to test it.
user_7788
Post by user_7788 » Feb 26th, ’14, 10:08
Where can i find your mail address ?
I have news :
For example, I've a Ctrl-Atl-U shortcut to change default audio device (bug appears wth Ctrl-U too).
When i do thi shortcut, it will work a first time. OK. When i try it again, i'll not work, but some other shortcuts will work (sound for example) and some of my auto-complete will not work...
To run it again, i've two choice
- right click on taskbar fastkeys icon --> reload
-go te settings and click save (wich is equal to a reload, i think ?)
Post by Marko » Feb 26th, ’14, 18:54
Are you using a non english Windows version?
In this case you need to change the following line of the command to the name of your sound window:
WinWaitActive,Sound
user_7788
Post by user_7788 » Feb 26th, ’14, 20:51
Thank you. I'm using a french version of windows.
where do i must change/put this command ?
Post by Marko » Feb 26th, ’14, 21:31
Open the shortcut and in the command field you will find the script. Change the third command line from WinWaitActive,Sound to
WinWaitActive,Son
I hope this will work and the translation is right. ;)
user_7788
Post by user_7788 » Feb 27th, ’14, 09:12
I'm really sorry but i don't understand :oops:
I don't know which script or wich command you're talking about :shock:
