fast google search
I wanted to know is there is a way to launch a instant googl search with a string I'll write. I explain.
For example, from anywhere I write gg mytext (then i press enter) and this will launch my browser with a google search "my text".
More of this.
Often, i start to write something in my google address bar without to know (when i start to write) if i want a "search" or a "get kucky". (i know this AFTER the string writed)
Would it be possible to, from anywhere, write gg mytext G (then enter, to launch a search with google) and if i write gg mytext L (then enter, will lauch get lucky) or if a wirte gg mytext W (will laucnch wikipedia searc)
I would like to (if i was working on a doc for example) my text "gg blabla G" be removed from my doc after the searching launched.
Thank you anyway for this beautiful software.
More of this.
Here is one idea. You can type "MyText ggg" or "MyText ggw" to search for MyText.
The code selects the word on the left by sending a Ctrl-Shift-Left, copies the selected word to the clipboard by Ctrl-C and finally runs a google/wiki search.
Use the Text Expander to set two entries:
1.
String: ggg
Type: Command
Substitute:
Options: Trigger immediately
2.
String: ggw
Type: Command
Substitute:
1.
String: ggg
Type: Command
Substitute:
send ^+{left}
Send ^c
Sleep 50
Run, http://www.google.com/search?q=%clipboard%2.
String: ggw
Type: Command
Substitute:
send ^+{left}
Send ^c
Sleep 50
Run, http://en.wikipedia.org/wiki/Special:Search?search=%Clipboard%Thank you a lot
I'm encountering two issues :
1 : when i write the code (even if i paste it) into my text expander substitute" and then i save it ; my "susbstitute" is blank whan i want to edit it. It seems to not save the code each time i write it.
2. This command is very good for a word, is there a way to do it for a sentence ? Eventually by taping first a ggg and then my string and then ggg again ?
Thank you
Thank you
here is the updated command which will search for the sentence on the left from the string.
send +{Home}^c
Sleep 50
StringGetPos, pos, Clipboard, ., r1
StringTrimLeft, MyClip, Clipboard, pos+1
myclip=%myclip%
Run, http://www.google.com/search?q=%MyClip%This was a great learning excercise for me, thanks. I study more Autohotkey commands as it looks like the possibilities are unlimited and anything can be done... I was already able to adapt the above slightly to suit my needs. Excellent!
