i'm runing into trouble by using the integrated calculator (Advanced Calculator.ahk).
If i get it what it says it's because my FastKeys is not installed in the standard path (C:\Program Files or whatever it is...).
The setup routine provides the ability to choose a different install location so this will run straight into trouble if someone chooses really a different location and you "hard code" it this way.
I replaced this "hardcoded" variable by setting the right path and it runs smoothly.
Please correct this little bug in one of your next releases.
Thnx
Achim
Hard coded Fastkeys path
This is not a bug. Advanced calculator is an example of external AutoHotkey script, just like many others. Feel free to update or change the script if needed.
