What's new in FastKeys 3.10:
May 21, 2016
With new macro - Insert Command Code - you can now embed AutoHotkey programming code into the Text Expander substitute string. For example, you can add message boxes, conditional jumps, complex conditions based on user input etc etc. Newly added Usage Statistics can be accessed from Tools menu and shows which modules you use the most and your estimated time savings. Please note that some FastKeys functions may reduce accuracy, it also only works with non-formatted text. No information is transmitted to us, of course.
- Added: New macro - Insert Command Code,
- Added: Usage statistics tracking,
- Improved error reporting,
- General improvements and bug fixes..
Download FastKeys HERE!
FastKeys 3.10 Released
Thank you for the update, Marko! It is working great as always.
