What's new in FastKeys 3.07:
January 17, 2016
Few interesting features have been added in this release. Multiple selections are now available in Run, Open and Script command types. This way you can set popup windows to select files to run etc. Copy to Start Menu option is available from right-click context menu and allows copying selected item(s) to Start Menu. You can select Tab and menu name - leave menu name blank if you do not wish to copy items as submenus. You can now add a description prefix to multiple selections and some Input Selection Forms to improve visibility - only description will appear on a menu. The default description separator is "::" and can be changed in Preferences/Text Expander/Description separator. Example:
Long response:: Thank you for your message. I will get back to you as soon as possible. Kind regards, John
/Short response:: Thank you for your message and kind regards, John
- Multiple selections available in more command types,
- Description prefix in multiple selection dialogs,
- Copy to Start Menu option,
- Column sorting,
Download FastKeys HERE!
FastKeys 3.07 Released
Marko,
Thank you for the additional functionality, much appreciated as always...JGM
Hi Marko
Will I loose any of my settings if I say "Yes" to upgrade to the latest version?
Thanks
Elliot
Thanks
Elliot
no, of course not. FastKeys updates preserve user settings.
