ChrisKey
Post
by ChrisKey » Dec 13th, ’16, 16:44
Hi
Apparently I made a mistake and now I get the error "Some Commands were stopped."
First of all a request for future versions:
Would it be possible to inform the user in more detail about the problem - e.g. which functions/shorcuts are involved?
There is also a link 'Show error report' which isn't working.
Is there a log file I can look into?
Thanks
Chris
Post
by Marko » Dec 13th, ’16, 17:02
Hi Chris, one of your commands contains a syntax error. Selecting "Show error report" should show more details - what's shown is your case?
Post
by Marko » Dec 13th, ’16, 18:47
The error message should appear. You can send us your settings.fdb file that we can see what might be the issue.
ChrisKey
Post
by ChrisKey » Dec 14th, ’16, 12:48
Thanks for your offer. I managed to find the problem -> it was a corrupt settings.ini file.
