Autocomplete "bug"
mragtronx8
Post by mragtronx8 » Mar 8th, ’25, 17:39
When I goto settings, and head to autocomplete, learned.txt.
When I open the learned.txt and try to delete an entry; the entry is deleted.
When I press save and press the ok BUTTON, the OK BUTTON does not respond.
If I goto the toolbar and press the X button, am prompted to save.
If I open the learned file, the deleted entry is still there.
Also when I close settings, and continue my work; AUTOCOMPLETE now is showing double results.
Video attached showing issue.
https://imagekit.io/tools/asset-public- ... 4A__%22%7D
Post by Marko » Mar 8th, ’25, 18:39
I tried on our end and cannot reproduce this, there must be something else. I suggest we discuss it via email.
mragtronx8
Post by mragtronx8 » Mar 8th, ’25, 18:47
email sent.
please advise steps to rectify/fix this issue.
Awaiting Reply...
mragtronx8
Post by mragtronx8 » Mar 8th, ’25, 23:05
https://ibb.co/LzFkNy6h
The setting highlighted in red "DISPLAY SUGGESTIONS AS YOU TYPE", is causing an issue [when turned on].
Am not 100% sure, but there is another setting in TEXT EXPANDER causing a problem.
a fix for "DISPLAY SUGGESTIONS" first is needed, to troubleshot the other settings.
mragtronx8
Post by mragtronx8 » Mar 15th, ’25, 20:21
Thank You for your Support.
Issue Fixed :D
