Brightness control with the mouse wheel
kavusha
Post by kavusha » Feb 6th, ’25, 14:03
Hi everybody,
it would be great to have a setting in the "Functions" section to control brightness with the mouse wheel. Much the same as it is the case with volume. For example placing the cursor on the bottom of the screen.
Regards.
Kavi.
Post by Marko » Feb 7th, ’25, 17:58
Search the Library - there are Brightness Up/Down commands available and you can trigger them with any shortcut. For example you could use
Ctrl + WheelUp - Brightness Up
Ctrl + WheelDown - Brightness Down
bitsper2nd
Post by bitsper2nd » Feb 7th, ’25, 19:32
You can add this to the startup script.
; Change brightness using scroll wheel in the left side of the screen
CoordMode, Mouse, Screen
#If isMouseAtEdge()
WheelDown::
    Brightness(-5)
Return
WheelUp::
    Brightness(5)
Return
#If
isMouseAtEdge(){
    MouseGetPos, x
    return x <= 1  ; Changed to check left edge
Brightness(Offset) {
    static wmi := ComObjGet("winmgmts:\\.\root\WMI")
        , last := wmi.ExecQuery("SELECT * FROM WmiMonitorBrightness").ItemIndex(0).CurrentBrightness
    level := Min(100, Max(1, last + Offset))
    if (level != last) {
        last := level
        wmi.ExecQuery("SELECT * FROM WmiMonitorBrightnessMethods").ItemIndex(0).WmiSetBrightness(0, level)
