Looking for more info on these two new pro features to help me decide whether to upgrade to v6 or not:
- NEW Grid Selection macro (Professional Edition)
- NEW Grid Check macro (Professional Edition)
I am a regular user of the selection table macro in v5 pro so am really curious to know what these two new features are and whether they help my use cases.
Cheers
Info Please on new v6 Professional Features
Please check our documentation about the new features:
Grid Check is similar to Selection Form Checkbox but it allows more flexible output definitions based on the status of the checkboxes (checked or unchecked). It can also group the outputs into more natural language.
https://fastkeysautomation.com/document ... Check.html
Grid Selection is even more powerful. Single or multiple selections are supported by using Radio and Checkbox controls which allows the output of more complex scenarios (surveys, questionaries etc.). Specific output per each combination can also be defined.
https://fastkeysautomation.com/document ... ction.html
