Shortcut - two keys pressed
ssystem
Post by ssystem » Apr 4th, ’14, 10:07
Is there a way to make a shortcut which would monitor all the keys on a keyboard? For example, I want my command triggered by pressing keys x and y together (x and y alone would not trigger anything).
I cannot find how to set this. Thanks.
Post by Marko » Apr 6th, ’14, 17:15
Look here: http://www.fastkeysautomation.com/forum ... tcut#p1004
Check for FastKeys updates, more advanced shortcut possibilities will be enabled in the next release.
Post by Marko » Apr 9th, ’14, 21:32
This has now been implemented. Double-click on a shortcut field and enter a shortcut according to AutoHotkey syntax.
For example, in you case you simply enter X & Y as a shortcut. Or better ~X & Y to keep the x and y keys functioning.
