Could you make the hotkey to open the clipboard manager open the actual clipboard manager?
Instead of that menu thing (whatever that's even supposed to be).
Clipboard Manager Hotkey
Thanks, we'll put it on our wish list.
There is also a bug with clipboard manager hotkey, if you set it to None for example by pressing Backspace in the settings>Clipboard Manager>Clipboard shortcut, after saving it is not saved. So if l wanna disable that clipboard manager l have to close the software.
I tried on two different computers and Clipboard shortcut setting in Preferences was saved correctly for me.
Another way to disable Clipboard Manager is to set the History size to 0.
