also use horizontal separators when "break menu at separator"
f@stkeys
Post by f@stkeys » Sep 21st, ’23, 20:32
If the user has selected:
Preferences > Start Menu > Menu 1 > More settings > Menu options > Break menu at separator
...how can the user also specify horizontal separators within the columns that are created?
In other words, sometimes a user doesn't want just columns, but to be able to vertically divide the columns.
Post by Tom » Sep 21st, ’23, 20:47
This is currently not possible. However, you could insert dummy empty items into the menu (for example Run command to non existing file) for the separation.
f@stkeys
Post by f@stkeys » Sep 21st, ’23, 21:26
Thank you, Tom!
Will try this workaround but of course would prefer to have official separators in use.
Perhaps instead of the "break menu at separator" option, in addition to normal menu Separators, there could be:
New Column
...in the context menu for Start Menu configuration, which would insert a column break into the menu list.
