Break Menu at Separator
Slickz
Post by Slickz » Oct 6th, ’22, 17:07
Hello, I added a separator in the start menu, but it does not work like I expect it to. Shouldn't it be breaking the menu after the separators ?
Please let me know how to get break menu at separator working. Thanks!
Post by Marko » Oct 6th, ’22, 17:54
"Break menu at separator" option divides the main menu into more columns and does not work for the sub menu.
But I wonder why the separators are not visible in your example, you can contact our support so we can analyze it into more details.
Slickz
Post by Slickz » Oct 11th, ’22, 08:13
Thanks Marko,
I'm giving fastkeys a try before I buy, trying to make sure it's what I need for my work. Thanks :)
