Listbox
Would be nice to be able to load a listbox (or similar) from a txt file
I'm not sure what you mean, You can use File Contents macro to insert the text from a txt file into the phrase.
Don't want to insert ALL the contents of the file.
Want to use each line in the file to load a Listbox/Dropdown choices.
Text File Lookup macro? This is available in the Professional Edition but you can try it during a trial.
Have enterprise.
That would be more useful if had a search at top and a listbox below it. If someone doesn't know what the choices actually are it is less helpful.
Would still be nice to be able to load shorter lists especially into ListBoxes and Comboboxes.
Ok, thanks. Isn't it easier to simply copy and paste the list into the box?
