Text Expander Seperator
JGM22
Post by JGM22 » Dec 8th, ’15, 20:06
I am trying to assign two different string names to the same text expander.
In the string name I have ABC/EFG ( in preferences the delimiter is / ).
I have closed out of FK and restarted it ( I also tried to reload ).
When I type ABC the text expander pops up. When I type EFG nothing happens.
Do I need to have two scripts in the Substitute field also separated by the delimiter / or can I simply assign two string names to use the single script ( which is what I am trying to do )?
Thank you...JGM
Post by Tom » Dec 9th, ’15, 10:17
There is an issue of recognizing separated strings when "Display suggestions as you type" option is enabled - it only shows the first one. Thanks for reporting.
JGM22
Post by JGM22 » Dec 9th, ’15, 14:28
Tom, thank you, much appreciated as always...JGM
