Convert an Excel Formula into FastKey?
DVT
Post by DVT » Dec 3rd, ’20, 20:51
Can someone help me convert this into Fast Key? I want to be able to use the input macro and only enter the sale price, mortgage price, and auto-populate the sentence. Also is there a way to auto add a comma on numbers once it exceeds 999? For example, "1000" becomes "1,000".
Excel
Formula
Post by Marko » Dec 4th, ’20, 12:04
Try using "Insert command code" macro, as shown in my other post.
For example, the command code could be
Send, % ThousandsSep(INPUT__Price * INPUT__Volume)
ThousandsSep(x, s=",") {
	return RegExReplace(x, "\G\d+?(?=(\d{3})+(?:\D|$))", "$0" s)
In such case use No output prefix "_" before the variable names ("_Price") to instruct FastKeys not to output the value.
DVT
Post by DVT » Dec 4th, ’20, 21:52
That's not working and I am struggling to get this to work. Can you show me using the formula above? That would be most helpful.
Post by Marko » Dec 5th, ’20, 11:24
The command (Type: Send) would look like this:
%INPUT__SalePrice%%INPUT__MortgagePrice%%CODE_Output%
Note the "_" prefix in front of the variable names (no output).
Use "Insert Command Code" macro with the following code:
DownPayment := INPUT__SalePrice - INPUT__MortgagePrice
DownPercent := Round((DownPayment/INPUT__SalePrice)*100, 0)
DownPaymentFormat := Thousands(DownPayment)
Send, % "The buyer placed a down payment of $" DownPaymentFormat " (" DownPercent "%) and financed the remaining balance."
Thousands(x, s=",") {
DVT
Post by DVT » Dec 6th, ’20, 10:50
Holy smokes, this works! Thank you so much Marko!
