Issue With Pasting A Word Containing The Letter L
TalGordin
Post by TalGordin » Aug 26th, ’19, 14:53
Hey!
I just downloaded the program for the first time and wanted to create a new settings file with lots of hotkeys. The only problem I've encountered is that as soon as my pasted text contains a word that contains the letter L, when I try to use the hotkey it pastes everything without the said word/letter, locks my computer and opens the "my computer" window. Is there any way to make this stop? I can't use the program without this being fixed :? Thanks in advance!
Some additional info:
-I tried switching the keys themselves but it doesn't help. Currently my hotkeys for this text are Win + Numpad4.
- I'm using Windows 7 64 bit, if that's relevant in any way.
Post by Marko » Aug 27th, ’19, 06:57
It seems to me that you have modifier characters enabled in Preferences/Text Expander.
The following modifier characters have a special meaning in FastKeys: ^ - Ctrl key, ! - Alt key, + - Shift key, # - Win key. This allows sending not only text but also other actions. The recognition of modifier characters can be enabled in Preferences > Text Expander.
