How to Pause Script
pwncpa
Post by pwncpa » Jul 12th, ’19, 21:48
Hi - I am trying to write a script to run some keystrokes in Excel and I need there to be a pause in the execution of the script. How do I insert some kind of 5 second pause? Thanks!
Post by Marko » Jul 12th, ’19, 22:06
More.../Macros/Pause
pwncpa
Post by pwncpa » Jul 12th, ’19, 22:54
That is greyed out for me when I have "Type" set to command. Isn't that the type I should have when writing a script like this?
Thanks btw!
Post by Marko » Jul 13th, ’19, 05:59
Sleep 5000
https://www.autohotkey.com/docs/commands/Sleep.htm
Post your command example to give you further recommendations.
