New to FastKeys... One Problem So Far
Steve Clark
Post by Steve Clark » May 4th, ’19, 18:47
New to FastKeys, like what I see so far. One simple problem...
I can't get the changes that I make in the user preferences to stick. Am I missing something?
I using Windows 10 Pro x64
Thanks
Steve
Steve Clark
Post by Steve Clark » May 4th, ’19, 19:08
Did a little research.
Took a look at the section with all the screenshots, I seem to be missing the "OK" buttons to
change these settings.
What's up?
Thanks again,
Steve
Post by Marko » May 5th, ’19, 02:47
Try to delete settings.ini file in FastKeys/Data folder to fully reset your settings.
Steve Clark
Post by Steve Clark » May 5th, ’19, 15:57
Thanks for your reply.
Tried your suggestion, no difference. I still don't see any buttons on the
bottom of any of the settings screens.
Tried reinstalling. Same thing.
Any other suggestions?
Thanks again,
Steve
Post by Marko » May 6th, ’19, 17:00
Strange. What’s your screen resolution? Can you send us a screenshot?
Steve Clark
Post by Steve Clark » May 7th, ’19, 02:29
Thanks again!
My resolution is at 1440 x 900
Here is a screenshot that will show you what I mean...
https://1drv.ms/u/s!AvS8YOocJVd6hWXQ-d8orthUwIrK
Thanks for any suggestions you have.
Steve Clark
Steve Clark
Post by Steve Clark » May 7th, ’19, 03:02
Hey,
I figured it out! It was the text scaling. I had it too high. I lowered it and I can finally see the buttons!
Thanks for your help.
Steve Clark
