Create a Te string to turn monitor off and it works for first time only but second time pressing the string doesn't work sometimes
steps --
1.after u press the string the monitor will turn off,now shake mouse the monitor will turn on again
2.now if u press the string again it doesn't work sometimes
3.I have trigger immediately and don't delete string enabled
win10 64bit
Te for turn monitor off doesn't work
Yes, true if you only shake the mouse, try to press a key or a mouse button to wake the screen.
This is not a bug. It's an AutoHotkey script which may help some users but may not work in all cases. If it doesn't work for you, you are free to search for the alternative or create one by yourself.
https://www.autohotkey.com/boards/viewtopic.php?t=14942
https://autohotkey.com/board/topic/8726 ... ff-screen/
