FastKeys 4.0 Released
Post by Marko » May 20th, ’17, 18:55
New major version release with many new features and improvements. Please let us know what you think.
What's new in FastKeys 4.0:
May 20, 2017
Release notes:
- Engine optimization,
- Sound notifications,
- File/Resume function - Restore data from backup files,
- Improved error reporting,
- Support for larger Input Selection Forms using scrollbar or by breaking to columns,
- Multiple equal Input/Select variables in the text now only require single user input,
- 'No output' _prefix available for Input/Select variables,
- New Selection Form type - Input,
- DateTime Selection Form can now accept free date and time formats,
- New Popups option: Transparency (%),
- New Popups option: Shadow type,
- New Selection Form option: Show titlebar,
- New Selection Form option: Break to columns to fit the screen,
- New Text Expander option: Use clipboard for Rich Text,
- Increased number of user variables,
Download FastKeys HERE!
gustms
Post by gustms » May 20th, ’17, 21:35
Thank you for the update!
Gryzor
Post by Gryzor » May 21st, ’17, 11:39
Ooh a major release!!! Thanks for the updates - this is by far the best and simplest utility for my needs, always :)
JoshT
Post by JoshT » May 21st, ’17, 13:01
Temporarily, I can not try the new, fourth version, can you tell me: is the Marking Menu implemented in the new version?
Gryzor
Post by Gryzor » May 21st, ’17, 16:55
Why would anyone... I had never heard of them but these look so awkward to use, never mind how they look. I'm all for trying new things but these are simply unworkable with a track pad. When on a mouse shortcuts are much faster to use anyway, and frankly, these solve a non-existent problem.
JoshT
Post by JoshT » May 21st, ’17, 18:19
Why would anyone...
Maya
Alias
Inventor
Blender
Modo
etc.
*sarcasm* Of course, this is absolutely awkward *sarcasm*
Personally, I need this feature for CAD where none MM / Pie Menu. 9 shortcuts (Q, W, E, A, S, D, Z, X, C) * (3 modificators Ctrl, Alt, Shift + 1) * 8 items in MM * 3 mouse button = 864 command.
Gryzor
Post by Gryzor » May 21st, ’17, 18:35
Yup, because you're going to remember 900 gesture paths, no problem.
When I said about shortcuts I meant the menu hotkeys, not actual shortcuts btw.
JoshT
Post by JoshT » May 21st, ’17, 19:27
In Modo, on 15 keys with piemenu, i have about 250-300 commands, sooo... yup, remembering few hundred command its not a problem. After a week of use, this becomes a reflex.
Gryzor
Post by Gryzor » May 21st, ’17, 19:36
Sooo... do you have an issue with hundreds of commands or not? In any case, you're the one who mentioned the number of commands, not I. And as I said, I wasn't talking about actual shortcuts.
Plus, from what I've seen on the video, this is not a solution for remembering long and complex commands, but for accessing menus more quickly. How would you organise 900 commands around a radial menu?
While we're on it (the video I mean), it looks like this could only work to the extend it does (saved a second, yay!) with small-depth and small-number of menus.
I could see a modifier (or more) for the context menu that would alter the contents where it could work for more complex things, but again how this would make radial menus a significant process is beyond me.
JoshT
Post by JoshT » May 21st, ’17, 21:35
I understood, you say about the menu hotkeys, i say radial menu much faster any linear menu.
Not only menus. You can write yourself, very looong and very cooomplex commands.
Its my problem. No? In addition, 108 radialmenu (~900 commands) is the POTENTIAL number of hotkeys for rm, i can choose the most convenient ones from them. Real number of commands, something about 4-24 on 1 hotkey.
Imagine, in a minute you press / execute - 5 hotkeys / commands - on each you save 1 second.
5 seconds a minute
5 minutes an hour
40 minutes in 8 hours, yay!
~ 3 hours a week, yay!
~ 13 hours in a month, yay!
~ 160 hours in a year, yay!
To create a context menu, you need to determine context
You? I dont know.
Anyway, i understand, you don't need such a possibility. OK.
