Bug: Start Menu edge menu does not update with changed resolution
jolly
Post by jolly » Apr 12th, ’25, 22:13
The start Menu edge detection does not properly update if you change monitor geometry.
For example, going from a standard 4k single monitor to 3 4k monitors. The Start Menu will start showing up in the middle of the screen
Post by Tom » Apr 13th, ’25, 07:16
This is not a bug, FastKeys needs to be reloaded after changing the monitor setup.
We will see if this could be improved in some of the future updates.
