SEND MONTH FORMULA IN CAPITAL LETTERS
Mr.Aky
Post by Mr.Aky » Feb 6th, ’25, 08:39
Is it possibile with a shortcut - Send - Macro Date and time send the name of the month in capital letters?
https://www.screenpresso.com/=nVNJc1FY2Wd0
As you can see the output is in lowercase
Post by Marko » Feb 7th, ’25, 17:53
You could enable "No output" option and then use Insert command code macro instead:
stringupper, DATETIME_Mese_prec, DATETIME_Mese_prec
Send, % DATETIME_Mese_prec
Mr.Aky
Post by Mr.Aky » Feb 10th, ’25, 07:05
Thanks, this works
