Shortcut to rotate between open windows
TheRealMarshall
Post by TheRealMarshall » Sep 30th, ’23, 20:53
I am looking for a shortcut that would have functionality similar to the Recent Files/Folders Menu shortcut, except it would only include my currently running applications. Its function would be the same as the functionality of ALT/Tab and would rotate between open windows. I need this because I am partially blind and use a screen reader, but I am having a problem where the screen reader is not reading me anything when I click alt-tab. So I am looking for a shortcut that would mimic the function, and give me that little popup that allows me to cycle through my running applications when I click the hotkey. Any help would be appreciated, thanks!
Post by Tom » Oct 2nd, ’23, 17:06
Try this (Type: Command):
Menu, Windows, Add
Menu, Windows, deleteAll
WinGet windows, List
Loop %windows%
	id := windows%A_Index%
	WinGetTitle title, ahk_id %id%
	If (title = "")
		continue
	WinGetClass class, ahk_id %id%
	If (class = "ApplicationFrameWindow")
		WinGetText, text, ahk_id %id%
		If (text = "")
			WinGet, style, style, ahk_id %id%
			If !(style = "0xB4CF0000")	 ; the window isn't minimized
				continue
	if !(style & 0xC00000) ; if the window doesn't have a title bar
		; If title not contains ...  ; add exceptions
			continue
	WinGet, Path, ProcessPath, ahk_id %id%
	Menu, Windows, Add, %title%, Activate_Window
	Try
		Menu, Windows, Icon, %title%, %Path%,, 0
	Catch
		Menu, Windows, Icon, %title%, %A_WinDir%\System32\SHELL32.dll, 3, 0
Menu, Windows, Show
Activate_Window:
	SetTitleMatchMode, 3
	WinGetClass, Class, %A_ThisMenuItem%
	If (Class="Windows.UI.Core.CoreWindow") ; the minimized window has another class
		WinActivate, %A_ThisMenuItem% ahk_class ApplicationFrameWindow
	else
Source: https://www.autohotkey.com/boards/viewtopic.php?t=74874
TheRealMarshall
Post by TheRealMarshall » Oct 3rd, ’23, 16:02
Wonderful, this works great. Thank you!
