%Cursor% in HTML text
marcelolima
Post by marcelolima » Jul 22nd, ’22, 12:06
Hello, Team.
Unfortunately the %Cursor% command doesn't work if we use the HTML text option.
Am I wrong?
Thanks so much.
Best Regards,
Marcelo.
Post by Tom » Jul 23rd, ’22, 08:39
You are right, cursor positioning will not work with HTML formatting. Try using "Insert file contents" macro to insert HTML file instead.
