Modify Font Size in Script
mragtronx8
Post by mragtronx8 » Sep 4th, ’21, 22:58
could u please advise how to decrease the font size "this script is from FASTKEYS library", and also advise how to change font type.
I tried to modify the values, but i end up having half the numbers showing "numbers not showing properly".
if WinExist("MyCountdown") {
Gui, 19:Destroy
SetTimer, ShowTimerCD, Off
else {
InputBox, secsLeft , Countdown, Countdown Seconds:,,160,123,,,,15
If ErrorLevel
Return
Gui 19:+LastFound +AlwaysOnTop -Caption +ToolWindow
Gui 19:Color, EEAA99
Gui 19:Font, s228
Gui 19:Margin, 0, 0
Gui 19:Add, Text, w335 h290 yp-50 Vdisp Cred Right
WinSet TransColor, EEAA99
Gui 19:Show, NoActivate, MyCountdown
SetTimer, ShowTimerCD, 1000
Gosub ShowTimerCD
Return
ShowTimerCD:
secsLeft--
IfEqual, secsLeft, 0
Loop 4
GuiControl, 19:Text, disp, 0
Sleep 400
Sleep 400
SetTimer ShowTimerCD, Off
;Sleep 3000
Gui, 19:Destroy
Else
GuiControl, 19:Text, disp, %secsLeft%
Return
Post by Tom » Sep 5th, ’21, 09:21
Play with the following two lines
Gui 19:Font, s100
Gui 19:Add, Text, w200 Vdisp Cred Right
mragtronx8
Post by mragtronx8 » Apr 9th, ’22, 18:11
please advise how to change the border and font color.
I changed the EEAA99 codes, but it didn't work.
PLEASE ADVISE.
Post by Marko » Apr 12th, ’22, 19:26
Gui 19:Add, Text, w335 h290 yp-50 Vdisp Cred cBlue
mragtronx8
Post by mragtronx8 » Apr 14th, ’22, 14:20
hi Marko,
thanx for the support.
what about the outer border color "white", if am setting to red or blue; there is still a white border around it.
can this also be changed?
Best Regards
Post by Marko » Apr 15th, ’22, 13:48
There is no border, the background is transparent.
Gui, 19:Destroy
else {
If ErrorLevel
Return
Gui 19:Font, s228
Gui 19:Margin, 0, 0
Gosub ShowTimerCD
Return
ShowTimerCD:
secsLeft--
Loop 4
Sleep 400
Sleep 400
;Sleep 3000
Gui, 19:Destroy
Else
Return
