Scroll page
davidp
Post by davidp » Apr 4th, ’21, 12:14
Use te to open sites,it opens site but can't scroll the page with up/right keys after opening the tab for some sites like win.softpedia.com,https://www.clipboardmaster.com/downloa ... oad.htmlxc
Also some times after the tab is opened it's not activated.
Latest ff beta
Post by Tom » Apr 4th, ’21, 20:00
Can you post the command example?
davidp
Post by davidp » Apr 5th, ’21, 09:24
No cmd,i use Run http://win.softpedia.com. In options trigger immediately and don't delete string are enabled,what cmd are u asking
Post by Marko » Apr 5th, ’21, 18:08
I tried and it always works for me, it must be something else.
davidp
Post by davidp » Apr 11th, ’21, 11:06
In win10 which ver have u tested,mine is v1909
Post by Tom » Apr 12th, ’21, 20:27
We use the latest Win10.
davidp
Post by davidp » Apr 17th, ’21, 18:15
I checked again it's not work,have u tested in latest ff beta
davidp
Post by davidp » Apr 23rd, ’21, 13:48
pls answer
Post by Tom » Apr 23rd, ’21, 17:29
we tested on the lasted Win10 and it worked on our computers.
