How about Categories for Text Expander
Steve Clark
Post by Steve Clark » Sep 23rd, ’19, 19:21
I use TE a lot. Having quite a few TEs, I think it would be great, just for the sake of organization, to be able to categorize
the different TEs. This feature is pretty common in most "Macro" programs.
Whaddaya Think? ;)
Thanks,
Steve
Post by Marko » Sep 24th, ’19, 12:43
You can currently organize into tabs and phrase files. Could you please give an example of the software with such feature?
Steve Clark
Post by Steve Clark » Sep 24th, ’19, 16:47
Ooo, sorry I didn't know about the tab thing. Thanks, I'll look in to that.
Sure, here are a few examples that I have personally used.
Shortkeys (I was using this when I purchased Fastkeys) https://www.shortkeys.com/
PhraseExpress (I've used this before) https://www.phraseexpress.com/
TextExpander (Software as a service) https://textexpander.com/
These are just a few examples of TE type programs.
One of the Macro Type Programs that I used to use which includes this function is
MacroExpress (Made by the same people who make shortkeys) https://www.macros.com/
Now you can see why I think FastKeys is such a GREAT value.
Hope that helps.
Thanks again,
Steve
Steve Clark
Post by Steve Clark » Sep 25th, ’19, 23:51
Ok,
Checked out the tabs. I think that will work fine.
Thanks again Marko
Steve
