Change system date to yesterday's date
Hello, I would like to hit a key, such as Ctrl-Y to change system date back to 1 day. For example, today is 7-30-19, will change to 7-29-19. And maybe Ctrl-T to switch back to today's date. Thanks
Try this with a shortcut (Type: Command)
You may need to change the date format in the second line.
Also, you may need to run FastKeys as administrator.
Result += -1, Days
FormatTime, Out, %Result%, dd-MM-yy
RunWait, %ComSpec% /c Date %Out%
