reverse date text
ego123
Post by ego123 » May 20th, ’19, 11:28
I need to change the existing date text
^dd.mm.yyyy
to
yyyy-mm-dd
The ^ indicates the cursor position before and after the change.
I tried the following send sequence without success:
{LShift down}{Right 3}{LShift up}^{vk58}{Right 7}-^{vk56}{Backspace}{Left 10}{LShift down}{Right 3}{LShift up}^{vk58}{Right 5}^{vk56}{Backspace}-{Left 8}{Down}
How can I do this?
Thanks
Post by Tom » May 20th, ’19, 15:26
Here is one way. Create a new shortcut, Type: Command
send ^c
sleep 100
stringsplit, OUT, clipboard, .
send {Del}%OUT3%-%OUT2%-%OUT1%
Select your date string and press a shortcut to make a change.
