Insert random quote
cyrilmalka
Post by cyrilmalka » Mar 11th, ’19, 11:11
I am VERY NEW to Fastkeys.
I would like it to insert a random quote in my signature in Thunderbird.
I have a text-fil in my documents: taglines.txt
I could find a short explanation here on the forum (viewtopic.php?f=6&t=68) but I don't understand at all what I have to write where. I'm afraid I'll need a couple more details.
Anyone could give me a step by step or a link where I can find a step by step?
Thank you in advance.
Regards,
Cyril
Post by Tom » Mar 11th, ’19, 14:43
Two ways:
1. Add a new item, select Type: Send, select "More... button/Macros/Input selection form" and copy the lines from your file to Selections field.
2. Use the script which reads the data from your file. Select Type: Command, copy the following script into the Command field:
FileRead, List, H:\data\MY DOCUMENTS\taglines.txt
Sort, List, Random
Send, % SubStr(List, 1, InStr(List, "`r`n")-1)
You may need to adjust the path in the first line and new line characters (`r`n), depending on your data format.
cyrilmalka
Post by cyrilmalka » Mar 11th, ’19, 18:40
Tom wrote: Mar 11th, ’19, 14:43 Two ways:
Sort, List, Random
Sort, List, Random
I used the way 2 and it worked.
Thank you very much.
Regards,
Cyril
Thou shalt keep thy religion to thyself.
