In the preloaded "Date and Time Options" I see "/%A_ShortDate%" which produces MM/DD/YYYY.
For filing purposes, I use the YYYY-MM-DD format (reverse order with dashes that are accepted in file names). How could I make this happen in FastKeys?
Alternative date format
Click on More button and select Date and Time options to choose desired formats. In your case the format would be
%A_YYYY%-%A_MM%-%A_DD%
