Loop Macro
Drakemoor
Post by Drakemoor » Feb 20th, ’23, 21:11
I'm trying to loop a macro and it works well, but I can't make it stop by pressing escape.
Loop, 3
CoordMode, Mouse, Screen
Sleep, 1203
MouseMove, 1644, 938
Send, {LButton}
Please help,
tnx
Post by Tom » Feb 21st, ’23, 21:31
This may work
Loop, 3
Sleep, 1203
Send, {LButton}
Sleep, 10
if GetKeyState("Esc","P")
        break
perfectrecall
Post by perfectrecall » Aug 16th, ’23, 06:59
Is there anything else I can do to stop command with one key? It did not run on my system.
glrobins
Post by glrobins » Aug 17th, ’23, 00:01
;ctrl-x to stop
^x::ExitApp
Post by Marko » Aug 20th, ’23, 20:48
Use the Reload shorcut to stop the loop - this can be defined in Preferences/General/Shortcuts.
perfectrecall
Post by perfectrecall » Aug 21st, ’23, 08:03
Reloading shortcut is an exact solution but it has a lag. It takes 2-3 seconds to reload/stop the shortcut. Even if it reloads the program immediately, the commands continue 2-3 seconds.
I think typing ExitApp to Startup Script or creating new command for ExitApp is the perfect solution.
