to open site with
Pls write a command to open a site when ctrl is pressed 2 times
Shortcut: Ctrl (you need to double click the shortcut entry field to enter it manually)
Type: Command
Command:
Type: Command
Command:
If (A_PriorHotKey = A_ThisHotKey and A_TimeSincePriorHotkey < 350)
Run, https://fastkeysautomation.com
In the shortcut entry field should i enter ctrl in capslock with c capital or how?pls write and show
You have the exact answer above, read it again. The caps doesn’t matter.
In the shortcut field entered Ctrl,Ctrl it didn't work even with non-capital entered as ctrl,ctrl still doesn't work
- marcelolima
I tested it and it worked perfectly! As examples, I tested with Notepad and Firefox.
* Please, avoid "flood" unnecessarily. The team is always available and helping users, but please respect that their time is as precious as yours.
Double click the shortcut entry field and enter “Ctrl” (caps doesn’t matter).
If this is not working for you, maybe the key is called differently in your Windows language setting. Sorry, I cannot help further.
