I'm using Macros > Insert Data > File Contents
to store a .txt file template that includes an emoji:
Meeting Notes
When I use my Text Expander string to trigger it, it comes out garbled:
、扨eeting Notes
Problem with emoji in Macro inserting data
Btw, the 'Send' code is simply:
where the emoji is stored inside the file.
%FILE_Meeting_txt%
I'm not a strong FastKeys user/programmer/etc. so I can't help you any more than pointing you to the link below that may lead you to a possible solution to your problem/issue/goal. The topic looks promising (relates to your question to an extent), but I'm not certain it will totally solve your problem, or be able to assist you in some way. Regardless, I wish you luck working through your issue to a satisfactory conclusion...
https://gitlab.com/smart-autohotkey/emojione
Try saving your txt file using "UTF-8 with BOM" encoding.vinidlidoo wrote: ↑Jun 1st, ’21, 01:53 When I use my Text Expander string to trigger it, it comes out garbled:
、扨eeting Notes
Thank you Tom. That solved my problem!
