Clipboard Manager - Selection
MALK
Post by MALK » May 1st, ’21, 13:35
I have set to open clipboard manager with history of clipboards by pressing Ctrl+Shift+V.
I also have enabled "Hold Ctrl key to press without formatting" option.
I wanted to ask, is there any way to select the clipboard item by pressing keyboard buttons? Right now, it seems to me that to paste the item without formatting I must keep pressing Ctrl key and select the item by using mouse.
Post by Marko » May 2nd, ’21, 13:39
You can use up and down keys and Enter or Tab to confirm.
