Moving the Mouse - Three Monitors
raymm3852
Post by raymm3852 » Apr 2nd, ’21, 21:01
I must be misunderstanding something.
I press F12 and record the below macro.
Command with:
MouseMove, -1093, 178
Send, {VK01 down}{VK01 up}
I run it and the cursor doesn't go to above location, it goes to the left edge of the left monitor.
Do I need to add something to tell the software which monitor?
Post by Tom » Apr 4th, ’21, 11:41
MouseMove command has issues in certain multi-monitor configurations. Try changing it with
DllCall("SetCursorPos", int, -1093, int, 178)
The first number is the X-coordinate and the second is the Y-coordinate.
