Script for calculating the difference between two dates, which doesn't work 100%...
Oblomov
Post by Oblomov » Apr 1st, ’21, 20:37
I'm trying to get 'HowLongYearsMonthsDays.ahk' working on FK, from:
http://www.computoredge.com/AutoHotkey/ ... ml#HowLong
Direct link to the script:
http://www.computoredge.com/AutoHotkey/ ... ays1.2.ahk
And it works just fine, but upon closing the window, it starts messing with FK, as though the script is still running somehow...
Not really sure if it's missing a 'return' somewhere, or the like...
Kind regards
Post by Marko » Apr 4th, ’21, 09:19
If you are using Type: Command you need to
Add this before creating a Gui (Gui, Add):
Gui, SpanCalc:Destroy
and remove the following last couple of lines, as they have impact on all scripts:
; Enable mousewheel in AutoHotkey GUIs
#If MouseIsOver("ahk_class AutoHotkeyGUI")
   WheelUp::Send {Up}
   WheelDown::Send {Down}
#If
MouseIsOver(WinTitle)
   MouseGetPos,,, Win
   Return WinExist(WinTitle . " ahk_id " . Win)
^!z::
  GuiControl, SpanCalc: , SysDateTimePick321, 20000101
Return
Oblomov
Post by Oblomov » Apr 4th, ’21, 17:47
Thanks for the feedback!
Would 'Gui, SpanCalc:Destroy' be placed here or between every Gui line perhaps?
HowLongAutoExec:
Gui, SpanCalc:Add, Text, , Enter Date One:
Gui, SpanCalc:Add, DateTime, vDate1, LongDate
Kind regards
Post by Marko » Apr 4th, ’21, 20:02
Just before first Add:
HowLongAutoExec:
Oblomov
Post by Oblomov » Apr 5th, ’21, 15:43
Marko wrote: Apr 4th, ’21, 20:02 Just before first Add:
HowLongAutoExec:
Gotcha, thanks! :D
