I don't really use any special script but sometimes when I use for example a simple text expander, for afew seconds my keyboard buttons get mad and every character is different from what they should be.
For example:
I have script to send/paste my email address and occasionally i get this chaos: myemail@}<;?: and after this every character on my keyboard is changed. I usually just hit random keys and after a while it turns back to normal.
I hope you can understand i don't really know how to write it.
The script above is just:
String: ,email
Type: Send
Text: myemail@something.com
Options: Trigger immadeitaley, Send raw text
ps: if it happens again, I try to insert some pictures or something
Sometimes FastKeys mux up my keyboard buttons
In which application?
Try to introduce a shortl Key Delay (50-100ms) in Preferences/Text Expander/Advanced.
I don't really know the applications, although it happened more times in Stack Borwser and maybe in Vivaldi?
I try that delay thanks for the advice
