Is it possible to use Fastkeys to process a regex search in a textbox?
alih1029
Post by alih1029 » Dec 1st, ’20, 00:55
Here's my Regex search:
SEARCH (?-s)(<img class.+?)\x20style=.+?>
REPLACE \1>
but i'm not sure how I could use fastkeys search through all mentions and replace any instances.
Post by Tom » Dec 1st, ’20, 22:24
Sure, you can use a AutoHotkey script in Type: Command. Here is the RegExReplace syntax:
https://www.autohotkey.com/docs/command ... eplace.htm
