Double and Triple ESC key
Ruud
Post by Ruud » Jul 7th, ’20, 17:50
I would like to make a new command.
Double tap on ESC key closes the window (send F4) (I know, already in the program, but I ruined it :-o )
Triple tap send a CTRL W
So I can close a window and close a TAB in Chrome
Is this possible?
cheers,
Ruud
Post by Tom » Jul 7th, ’20, 19:42
You can still load the example from the Library - search for "Double".
This one would close the window or tab (if in Chrome) on Esc double press:
WinGetClass Class, A
If (A_ThisHotKey = A_PriorHotkey && A_TimeSincePriorHotkey < 350)
	If (Class="Chrome_WidgetWin_1")
  		Send ^{vk57} ;Ctrl w
 	Else
  		Send !{F4}
Ruud
Post by Ruud » Jul 8th, ’20, 10:55
Hi tom,
Thx for the quick reply and the perfect solution!
And also for the tip to search for the original in the library
I only had to remove the accolade from your script.
Many thanks from a almost 60 years young dutch guy who is stil learning
Cheers
Ruud
mros
Post by mros » Oct 6th, ’22, 15:59
Hi Tom,
This is my first post. I'd like to create a version of this that would require a "triple Esc" instead of double. How would I do that, please?
Thanks in advance,
Michael
Tom wrote: Jul 7th, ’20, 19:42 You can still load the example from the Library - search for "Double".
 	Else
  		Send !{F4}
Post by Marko » Oct 6th, ’22, 18:28
Try this:
	PressCount:=PressCount+1
	if (PressCount=2)
		Else
			Send !{F4}
else
	PressCount:=0
mros
Post by mros » Oct 12th, ’22, 15:54
Thank you very much, Marko, that was exactly what I needed!
Much appreciated!
