AutoCopy the Selected Text to Clipboard by Mouse Lbutton
Admirer
Post by Admirer » Aug 25th, ’19, 05:53
This is one of the default commands of Fastkeys under Shortcuts. The command script goes like this:
md_treshold:=20 ;pixels
MouseGetPos, mdx, mdy
KeyWait LButton
MouseGetPos, mdx2, mdy2
if (abs(mdx2-mdx)>md_treshold or abs(mdy2-mdy)>md_treshold)
   SendInput ^{vk43} ;Ctrl C
There is a little problem though.
Generally, we select the text by one of the following methods:
1. By holding down left mouse button and dragging the cursor (traditional mehtod! :| )
2. Using the combination of shift key and rt-lt arrows (used by skilled typists 8-) )
3. By double clicking a word or url or, tripple clicking a whole sentence.(preferred by modern geeks ;) )
Now, I observed that this command works only after 1. Doesn't copy the text selected by methods 2 and 3. It will be really great if it could execute in all these three instances. (Although, Ctrl+C works in all 3)
Post by Marko » Aug 25th, ’19, 09:46
Admirer
Post by Admirer » Aug 26th, ’19, 05:09
Replaced the original code with the following code.
This code gives Error at Line 45
Line Text: ~LButton
Error: Duplicate hotkey
;Auto copy clipboard
~Lshift::
TimeButtonDown = %A_TickCount%
; Wait for it to be released
Loop
   Sleep 10
   GetKeyState, LshiftState, Lshift, P
   if LshiftState = U  ; Button has been released.
      break
   elapsed = %A_TickCount%
   elapsed -= %TimeButtonDown%
   if elapsed > 200  ; Button was held down long enough
      x0 = A_CaretX
      y0 = A_CaretY
      Loop
     Sleep 20                    ; yield time to others
     GetKeyState keystate, Lshift
     IfEqual keystate, U, {
       x = A_CaretX
       y = A_CaretY
       break
   if (x-x0 > 5 or x-x0 < -5 or y-y0 > 5 or y-y0 < -5)
   {                             ; Caret has moved
      clip0 := ClipBoardAll      ; save old clipboard
      ;ClipBoard =
      Send ^c                    ; selection -> clipboard
      ClipWait 1, 1              ; restore clipboard if no data
      IfEqual ClipBoard,, SetEnv ClipBoard, %clip0%
~LButton::
MouseGetPos, xx
Loop
   Sleep 10
   GetKeyState, LButtonState, LButton, P
   if LButtonState = U  ; Button has been released.
      If WinActive("Crimson Editor") and (xx < 25) ; Single Click in the Selection Area of CE
         Send, ^c
      break
   if elapsed > 200  ; Button was held down too long, so assume it's not a double-click.
      MouseGetPos x0, y0            ; save start mouse position
      Loop
     GetKeyState keystate, LButton
       MouseGetPos x, y          ; position when button released
       break
   {                             ; mouse has moved
      ;ClipBoard =
; Otherwise, button was released quickly enough.  Wait to see if it's a double-click:
TimeButtonUp = %A_TickCount%
Loop
   Sleep 10
   if LButtonState = D  ; Button has been pressed down again.
      break
   elapsed -= %TimeButtonUp%
   if elapsed > 350  ; No click has occurred within the allowed time, so assume it's not a double-click.
;Button pressed down again, it's at least a double-click
TimeButtonUp2 = %A_TickCount%
Loop
   Sleep 10
   GetKeyState, LButtonState2, LButton, P
   if LButtonState2 = U  ; Button has been released a 2nd time, let's see if it's a tripple-click.
      break
;Button released a 2nd time
TimeButtonUp3 = %A_TickCount%
Loop
   Sleep 10
   GetKeyState, LButtonState3, LButton, P
   if LButtonState3 = D  ; Button has been pressed down a 3rd time.
      break
   if elapsed > 350  ; No click has occurred within the allowed time, so assume it's not a tripple-click.
   {  ;Double-click
      Send, ^c
;Tripple-click:
   Sleep, 100
   Send, ^c
~^a::Send, ^c ;Ctl+A = Select All, then Copy
Post by Marko » Aug 26th, ’19, 07:34
You should not include a shortcut definition in the code (remove ~Lshift::).
This works for me to capture a double-click. Others would require separate shortcuts.
Shortcut: LButton (with the ~Native option)
Loop
   Sleep 10
      break
      Loop
       break
   {                             ; mouse has moved
      ;ClipBoard =
Loop
   Sleep 10
      break
      ;MouseClick, Left
; Since above didn't return, it's a double-click:
   Sleep, 100
   Send, ^c
Admirer
Post by Admirer » Aug 27th, ’19, 07:57
Wanted to create following short-cuts:
~Lshift:: and ~^a
But can't find "Lshift" and "^" keys in the short cut menu.
Post by Marko » Aug 27th, ’19, 14:39
~LShift - Shift with Left and Native options
~^a - Ctrl + A with Native option
Or double-click the shortcut field and enter the shortcut (for example ~^a).
Admirer
Post by Admirer » Aug 28th, ’19, 05:48
Thanks.
Now I could split the code in three different parts which enables auto copy of the selected text by different methods and save much time. Giving it below for those who wish to add these short cuts in their settings:
1. Auto copy of selection done by Single/double/triple click
Short cut: ~Lbutton Type – command
Script:
MouseGetPos, xx
Loop
   Sleep 10
         Send, ^c
      break
      Loop
       break
   {                             ; mouse has moved
      ;ClipBoard =
Loop
   Sleep 10
      break
Loop
   Sleep 10
      break
Loop
   Sleep 10
      break
   {  ;Double-click
      Send, ^c
;Tripple-click:
   Sleep, 100
   Send, ^c
2. Auto copy of selection done by Shift – arrows (~LShift - Shift with Left and Native options)
Short cut: ~Lshift Type – command
Script:
Loop
   Sleep 10
      break
      x0 = A_CaretX
      y0 = A_CaretY
      Loop
       x = A_CaretX
       y = A_CaretY
       break
   {                             ; Caret has moved
      ;ClipBoard =
3.Auto copy of selection done by Ctrl + A (~^a : Ctrl + A with Native option)
Short cut : ~^a Type: command
Script:
The only thing that remains is that it does copy the url from address bar!!
