Te at end
davidp
Post by davidp » Jun 19th, ’19, 14:15
I have created te(text expander) strings to open pics with xlideit image viewer but sometimes it open's minimized,how to always open it maximized
davidp
Post by davidp » Jun 19th, ’19, 14:48
1.Add a shortcut for new in te module
2.to ok in the te window
https://ibb.co/Xkvbh4j
3.move things in te module to up/down by one level and to move things in te module to top/bottom
https://i.ibb.co/7QXrWPY/fk2.jpg
davidp
Post by davidp » Jun 19th, ’19, 14:53
Whenever a new te string is created it's always added somewhere in between,add it to the end
davidp
Post by davidp » Jun 20th, ’19, 16:40
Te strings to open sites,shutdown,restart,sleep doesn't work sometimes.Doesn't work for xyplorer,dextronet sites.
Post by Marko » Jun 20th, ’19, 21:00
This issue reports are not very helpful, you should try to specify reproducible steps that we can recreate the issue on our system.
Also, I'm not sure I understand all described issues/requests. ;)
davidp
Post by davidp » Jun 22nd, ’19, 10:28
Pls first make the above 4 posts into seperate topics bcoz it will be difficult to answer and repro
davidp
Post by davidp » Jul 3rd, ’19, 08:27
I've edited
Post by Marko » Jul 4th, ’19, 15:27
Run, MySoftware.exe,, Max
https://www.autohotkey.com/docs/commands/Run.htm
You can select multiple items and drag and drop them.
New item is created at the bottom of the list or above the selected item. Click on the empty space below items to ensure the item is added to the bottom.
Please show the example which doesn't work.
davidp
Post by davidp » Jul 4th, ’19, 17:27
You can select multiple items and drag and drop them.[/quote]
But that's done by mouse which is difficult many times to do with,add a kb shortcut
For opening maximized i tried like this but didn't work(read ur link)
In the substitute field i type - Run, Xlideit.exe D:\g\c1.jpg[,, Max
Pls correct it
Post by Marko » Jul 11th, ’19, 06:37
Run, Xlideit.exe D:\g\c1.jpg,, Max
