Make Clipboard Manager setting more transparent
NW5o4vTsxVyAY4AY
Post by NW5o4vTsxVyAY4AY » Feb 27th, ’19, 18:50
Hi everyone,
when you don't have any Clipboard shortcut set under Preferences -> Functions -> Clipboard Manager, the program considers that function to be completely off.
So even if you turned on the clipboard items under Preferences -> Start Menu-> Menu Options, copied items won't be saved.
I find it a bit odd that you have to set a Clipboard shortcut just to enable that function, even if a person never intends to use it this way because she/he only wants to use the Start Menu.
It's no big deal of course, because you can just set a shortcut that you'd never use anyway.
But maybe it's still something to look into if possible.
Post by Marko » Mar 2nd, ’19, 17:13
Thanks, I see what you mean, we'll take a look. ;)
Post by Marko » Jun 2nd, ’19, 16:18
This should be resolved in 4.19.
