Hello
Autolearning is learning even strings which are set not to be learned after latest update. Please check video.
http://imgbox.com/LjWd0BY3
added string "test" (without the quotes) to exclusion list. Wrote test1234 4 times and it was saved in the learned file!
Auto learning feature learn even disallowed strings
Sorry, I tried and can't reproduce this.
- what's the "Don't learn strings" entry (the video is small)?
- how do you open Quick find?
Hello Tom
I retried again and am able to replicate the issue.
For the sake of example I used test as the string and wrote test1234 3 times and the same was saved in the file.
Please find image attached.
http://imgbox.com/VTYdLdKB
The quick find was opened by alt+space shortcut.
Hm, I still cannot reproduce it on our side. Could you send your settings.fdb and settings.ini files to our support mail that we can check what might be the issue?
Hello Tom
I have sent the files on email. Kindly check. Regards.
Great support from developer. Issue resolved. The error was due to ( character in the dont learn strings. Removing it resolved the issue.
