Custom location for Text Expander strings
CanyonR
Post by CanyonR » Jun 19th, ’13, 15:00
Second suggestion:
It would be great if there was a setting for a custom location for the 'strings.txt' file that holds the Text Expander settings. Right now i'm manually syncing that file between computers using Google Drive. If I was able to specify the location in the same way as the 'scripts folder' and the 'Phrase files folder' then I could just point it to a copy in my Google drive (or Dropbox) folder and it would be consistent across all my computers.
Thanks,
Canyon R
Post by Marko » Jun 21st, ’13, 06:52
Hi Canyon,
Thanks, this is actually a frequent request and is already foreseen to be implemented in the next release.
OldFaithful
Post by OldFaithful » Jun 23rd, ’13, 07:44
Great news, thanks.
Post by Marko » Jul 9th, ’13, 11:58
Hi, next release is in the final testing. User will be able to define the folder where the data is saved.
Stay tuned.
Post by Marko » Jul 12th, ’13, 21:41
This was a frequently requested feature and is now implemented in Version 1.10 (out today).
Could you please let me know how you like it or have any other ideas. Thanks!
JamesMls
Post by JamesMls » Jul 15th, ’13, 23:31
Looks good, I'll definitely use this feature. Thanks for your great support! :) ;) :)
Post by Marko » Nov 22nd, ’13, 13:03
Hi everyone,
the file management system has been introduced in version 2.04. Now you can have more settings files. Also, settings are now saved in one single file.
I hope you will like it.
